Whenever I try to access KMPlayer the following error displays while Windows 8 goes to sleep. I have spent many hours searching for the solution but I could not find anything else.
Can I get your suggestion to fix this issue permanently?
I would be grateful to you.
Thanks in advance.
System Error.Code:5.
Access is denied.
Try to access KMPlayer error displays while Windows 8 goes to sleep
Hello Dominic
It seems like you have installed a wrong version of KMPlayer that does not work on Windows 8. Please uninstall it (Control Panel -> Programs -> Programs and Features) and access the link I have provided you with. Right click on the installer and choose Run as administrator, and after the installation is complete, right click on kmplayer.exe, click Properties, and under the Compatibility tab, choose Run this program in compatibility mode for Windows 8.
KMPlayer Download
I hope you will find this information useful.
Randolph
You need an Administrator confirmation that will allow you to access this king of software to your computer. To do this just follow the instructions below:
Step 1: Right Click the software then selects the Run As Administrator
Step 2: It will prompt you if you want the following program to make changes to your computer just click yes.
You can also try this:
Step 1: Press the "Windows Key" and "Q" on your keyboard
Step 2: Enter "command"
Step 3: Then right click the "Command Prompt" tile.
Step 4: Click the "Run As Administrator"
Step 5: Enter this following command:
               "Net user administrator /active: yes"
Step 6: Launch the application
