This error message appears while I was installing the Microsoft Office Professional Plus 2010:
Error 1731.The source installation package for the product Microsoft Office Office 64-bit Components 2010 is out of sync with the client package. Try the installation again using a valid copy of the installation package 'Office64WW.msl'.
Any suggestion to resolve this would be greatly appreciated. Thank you.
Try the installation using a valid copy of the installation package ‘Office64WW.msl’
Hello Guerrero,
This problem occurs because you still have pre release office 2010 in your system, may be a BETA or RC version.
Solution:
Go to Control panel > Add remove program > Delete all office 2010.
When complete removal is done then you will be able to install Office 2010 successfully.
Hope this would help you.
Thank you.
First, try acquiring a legit or an official copy of Microsoft Office 2010, as this will resolve your problem. You may acquire a copy of Microsoft Office Professional Plus 2012 thru Microsoft's official webstore, amazon and other online market sites, and your local tech store. This will not only save you time, but also gives you additional support when using Microsoft products.
