Try to open Icofx in Windows Vista SP1 it crashes
When I try to open Icofx in Windows Vista Home Premium Service Pack 1, it crashes with this info that Windows Vista gathered. How can I remove this error? Can you provide me the solution? Any help would be appreciated. Thanks.
Exception EOleSysError in module IcoFx.exe at 00075331
Exception EOleSysError in module IcoFx.exe at 00075331.
No such interface supported.
OK
Answered By 5 points N/A #175885
Hello David
After doing a little research, it seems that I might be able to help you with your IcoFx.exe module error.
The problem is actually a corrupted file, inside the program.
And in order for you to solve this, you must download a error repair tool.
I will provide you with the link. Just click save and install RegTweaker
After installation, open it and click the Scan button. After scanning is complete, press the Repair Now button.
The software will clear every error and damaged dll found into your computer.
And there it is. IcoFx now functions properly, without any errors.
I hope this information will help you solve your problem.
Randolph
Answered By 590495 points N/A #309549
That is an exception error which is probably caused by a problem in the program itself. Normally, the trial version of IcoFX works up to 30 days and after that the save function will stop working. This means once you’ve exhausted the 30-day period, you will no longer be able to save your work.
I’m not just sure if the exception error you encountered is related to the trial period because it should affect only the save feature of the application. Anyway, just try uninstalling the application and install the latest. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select IcoFX among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This will remove everything the program created on your computer. When it is finished, close Revo Uninstaller and download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system.
When it is finished, close CCleaner and download the latest free trial of IcoFX and install it. This should fix the problem. The latest version at the moment supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 2 GHz Intel Pentium or equivalent AMD Athlon or faster processor, 512 MB RAM, and 50 MB free space.
If you want to convert CCleaner to Pro, download the codes and follow the instructions.
