Trying to burn disc in iDVD 6 after installing it on Mac
I was trying to burn a disc in iDVD 6 after installing it on Mac, the burn failed with the message, "Errors were found during the burning process. Any ideas?
Burning Finished  Errors were found during burning process  The error #-34502 was reported…
Burning Finished
Answered By 0 points N/A #176297
Dwight,
Depending on what is on the original, you may need to adjust media settings to “standard size” for the burn to be successful. It may just be one of your buttons that is outside of the standard (4:3) TV safe area (even if the project is 16:9 widescreen).
To correct this, go to the View menu and then Preview your iDVS project. Turn both the “Show Standard Crop Area” and “Show TV Safe Area” on and see if any buttons are outside of the innermost area. You can tell if they are if the by hovering the cursor over the button and seeing if its outline draws. If it does not, the button is outside.
