johan weiz
20 points
Posted on - 04/14/2012
I know that my connection in MS Exchange Server is Ok when I first tried it. But now, when I attempted to connect it, I get this pop-up message:
“Trying to Connect to Microsoft Exchange Server.”
And then sometimes this error: MAPI_E_LOGON_FAILED
What can I do to fix this?
Trying to Connect Error in MSExchange Server
There are 4 reasons why a user may get the error message MAPI_E_LOGON_FAILED in MS Exchange Server:
You are accessing a mailbox that does not exist or the logon information is invalid
You don’t have sufficient rights on the Exchange mailbox you are trying to access
You are running code in ASP or Active Server Page and you have insufficient rights on the IIS or the Microsoft Internet Information Server computer
You are relying on the password synchronization in IIS version 4.0 in order to authenticate the Anonymous User which is specified in IIS
To have this issue resolve, you can try modifying the registry by doing the following:
Go to Start
Click on Run
Type regedit
Hit OK
Look for the click the registry key: HKEY_LOCAL_MACHINESystemCurrentControlSetServicesNTDS
Go to Edit menu
Choose New
Click Key
Type Parameters
Hit Enter
Click on the Parameters key
Go to Edit menu
Choose New
Click on DWORD Value
Type in NSPI max sessions per user
Press on Enter
Double-click on NSPI max sessions per user
Type the number of the required NSPI connections
Click on OK
For further assistance on this matter, you may also visit https://support.microsoft.com/en-us/help/2019948/error-trying-to-connect-to-microsoft-exchange-server-results-in-mapi-e.
