What is the solution to this problem? I am trying to use convert PDF Files into MS Word Easy when it shows an error.
PDF file user_guide. pdf is not password protected. Please choose a different PDF file and try again.
Trying to convert PDF Files into MS Word but failed
Not all PDF files can be converted to MSWord. The system requires that the PDF be created from a text mode. If not from a text mode, then it will give errors. If the PDF contains written documents n form of images, them the data cannot be retrieved in characters, it requires the image format.
You have one possible solution, you may try some other software, or that you have to copy the entire PDF as image into WORD. There are some character recognition tools available in the internet. Try to use them in order that they may retrieve the data from your PDF file.
Please see the attached document for your solution with image.
First Open the PDF converter.
Then open the desire file
Then you will see below dialog box
Then press ok button and then another dialog box will come then press save button .
Then the conversion will take place and you will see below message.
At f the final stage if you press ok button the PDF file will open on MS Word file.
If you are using a third-party software to convert PDF files to Microsoft Office Word format, you should try a free online conversion tool that will not require any installation. If you need to convert PDF files to Microsoft Office Word document format, try first Convert PDF to Word Online. I tried it before and it works perfectly.
This online tool allows you to convert your files easily and download them immediately right after you converted it. No email address or other stuff is required to get the converted file. The tool allows you to convert the following:
- DOCX to DOC
- ODT to DOC
- SXW to DOC
- RTF to DOC
- WPD to DOC
- TXT to DOC
- PDF to DOC
- HTML to DOC
You can upload your files in four (4) ways: Dropbox, Google Drive, URL, and or selecting it directly from your hard drive. Another one you can try is Pdf to Doc. This tool supports only one method of uploading your file: by selecting it from your hard drive. Another one is PDF to Word Converter.
