Trying to edit data in OmniTrader gives object reference error
Hello Experts,
When I click on the Edit Data in the Focus List right click menu, I get the error ‘Object reference not set to an instance of an object’. I do not have any problem with running OT2013 Pro with MetaStock EOD data. I can load charts and run ToDoList and can do all kinds of analysis. The problem is when I right click on a symbol in Focus List and then click ‘Edit Data’ instead of opening the editor window. Then I receive this error. Did anyone face a similar issue? What can be done to resolve this issue? I am looking forward to your responses to fix this issue. Thank you.
Error -2147467261: Object reference not set to an instance of an object.
Occurred in routine 116 – frmDataEdit.frm .LoadData
Please not this error or send a copy of ‘OT.log’ to:
Nirvana Technical Support, at (512) 345-2592
EMail: [email protected]
Fax: (512) 345-4225
