I got an error message which states that:
I downloaded Window Media Players few days ago. Today I tried to install it but I can not do this because an error message occurred:
As I was attempting to open my WMP. I used "SFC /scan now" and nothing happened. I used “unregmp2.exe /Update WMP Edition” to try and fix the problem. I did nothing to the DVD ROM, and today I cannot print from my printer because if I try to click ‘Print’ my MS Word pauses/hangs (or whatever program I am in). What should I do? Please help?
Windows Media Player
The file wmploc.dll has a version number of 11.0.6001.7000 where 11.0.6002.16489 was expected.
Windows Media Player is not installed properly and must be reinstalled.
Do you want to install the Player from the Microsoft Web site?
Trying to fix wmploc.dll error and printing stopped instead
When you install/uninstall or modifying any new programs or any new features then wmploc.dll file is deleted from your registry editor. So be careful when installing new programs into your PC. If you don’t want to losE your wmploc.dll file then it is strongly recommended for you. I am giving you one link. You can check your wmploc.dll errors by directly from this link:
After checking your wmploc.dll if you found wmploc.dll lost notice then no problem. Here is the download ink:
Download your wmploc.dll file from here. And install it. After install you will be notified by windows.
Hope your registry settings will be solved.
Arsalan
Hello Dear Matthew L Peters,
Dear it is not a much higher problem.
You have not installed windows media player correctly. Or it is also be assumed that you have not installed proper codec pack to play files.
First try to reinstall windows media player a latest version. Go to Microsoft site and download windows media player from there.
This installation will resolve your problem.
Hello Metthew,
There is conflict between your DLL files. When you downloaded the Windows media player it came with the previous version of the DLL file (wmploc.dll). Since now you are trying to install it, Windows has upgraded the DLL file and you still have the older version in the setup. The solution is simple. Download the upgraded wmploc.dll file and replace it with the previous version. Install it again. You will face no problem.
