Trying to install ESET NOD32 in my computer
Hello Dear,
You are facing problem in installing ESET NOD32 antivirus in your computer. You are using windows operating system. You want help to install ESET NOD32 in your computer. Here are some solutions for you. Please follow the instruction.
** First uninstall other antivirus from your computer.
** Go to program files and delete directory files of antivirus if found.
** Now go to ESET NOD32 website.
** Download ESET NOD32 installer.
** You don’t need to select your operating system; the installer will automatically select the operating system.
** Double click on the ESET NOD32 installer.
** It will start downloading the antivirus for your operating system.
** Follow the further instruction given by the software.
** After completing installation restart your computer.
** Now activate trial version of ESET NOD32 or buy the key.
** Update ESET NOD32.
**Your antivirus is ready to use.
I hope my information will help you.
Have a nice day.
Thank you.
If you want to reset ESET NOD32 to factory defaults, follow the steps below:
1. Launch ESET and then click Start then All Programs. Go to ESET Folder and then ESET NOD32 Antivirus Folder. Go to ESET NOD32 Antivirus.
2. Press the F5 function key to launch the Advanced Option menu.
3. Click Default button as shown in the picture:
4. Choose Revert All Settings to Default and then click the Yes button. This will reset the advanced settings to factory settings.
5. You can revert the settings for a selected category. Just select which category you would like to reset.
6. Choose Revert only (Category) settings to Defaults.
