stevenjesus
10 points
Posted on - 11/09/2011
   Tried accessing a computer a in a network group but i keep getting this message on my screen
"Operation failed because domain controller could not be contacted that contained an account for this computer. Network the computer to rejoin the domain.
Thanks
lee hung
75 points
Trying to login into a remote computer
Hello Steven,
Your computer is no longer on the domain of the network and therefore you will need to reconfigure the settings and restore it to the network. Use the following procedure:
Go to my computer and then right click, next click on properties.
In the window that will open look for workgroup and the click change settings. Change the workgroup name to the name you are using for all the computers on the network and then save the changes,
If you are using a linux system then you will have to access the Yeast and change the domain membership settings from there.
__
Regards
Lee Hung
Its pretty simple, both your computer and the computer that you are trying to access is not in the same network. It will really not meet so if your no the administrator, then I suggest you ask him to make you PC or the computer you are accessing meet in a single domain network, most probably the domain network that all of your PC is connected to. It is also possible that someone is using the computer and you have same kind of right in that particular computer. This happens if both accounts are the administrator accounts and it will really not connect if this is the case.
