I was trying to open a sample package in RAD Studio 7.0, but for some reason the following error pops out:
"Error
Can't load package C:UsersPublicDocumentsRAD
Studio7.0BplSamplePackage1.bpl.
The specified module could not be found.
Do you want to attempt to load this package the next
time a project is loaded?"
Does anybody know why I got this error and how can I solve it?
Thanks, Mark.
Trying to Open RAD Studio 7.0
There is a problem with the bpl file that you want to load. For you to fix that, find or look for right bpl file from the source where you get the package. That is the best thing that you can do if you really want to install that version of RAD.
I have another option which I think will be the best solution for this problem. Download the RAD Studio XE2. It is the latest version of RAD and you will not encounter that error here. All you need to do is to download RAD Studio XE2.
You can download the trial or buy.
