Trying to reactivate the Parametric cell studio.
When I am trying to reactivate the Parametric cell studio form in order to have more postings, the following error message is being show (see image below).
I have tried it several times, using various methods, but couldn’t get through.
Reevaluation Error
An evaluation error has occurred. This may be caused by one or more dependencies becoming invalid.
Details
Action: Error
Reason: The value you entered is too small.
Can someone please help me.
Thanks a lot.
Answered By 590495 points N/A #145028
If this is the first time it happened with your application, try restarting your computer then try it again. If it doesn’t work, try reinstalling the whole program. Uninstall Parametric Cell Studio then check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. Install Parametric Cell Studio again after this and then check if this fixes the problem.
You may also try upgrading your current version to the latest version if the problem continues.
