Trying to edit the EXE file then must check on this EXE to source code converter
What is a source code? What is .exe code? How to convert the executable (.exe) file to the readable source code? How to convert exe to source code converter?
Source code: source code is something which is designed for the coding which is helpful for the users to understand how the executable is made and the working of the Exe file.
.EXE: Executable code is a binary code which is done for the source code, so we have something called has the Decoders which is used to decode the .exe file and make it to readable and understandable format for the users. Generally, decoders are considered to be the imp tools for the Hackers and also called as the Reverse Engineering.
So how can we convert the .exe file/application to some source code into the readable format?
Don’t worry their ways to change the executable file to source code
There are a few software’s available on the net
But I’ll personally recommend a software which I use to decode the executable file
You can download it here
After downloading the file. Install it in your Pc and launch it.
Once the software is installed browse the file which you want to convert to source code and select the file.
Once the file is selected, it will taka few seconds to decode the executable file, and then the output will be in the.The net format which you can convert to your readable language later on.
Like this how we can change the executable file to the source code which users can understand.
If you’re much interested in coding, you can convert the source code and improvise the software too.
