I was trying to uninstall Immunet but this error shows. What’s the dut.dll File?
How can I solve this error?
I reinstalled the application but I could not fix this problem. Any idea would be really appreciated.
Thanks in advance.
Updater.exe – Unable To Locate
This application has failed to start because dut.dll was not found.
Re-installing the application may fix this problem.
OK
Trying to uninstall Immunet and this error message appears
Hi Robert,
If you really want to uninstall the Immunet just go to Control Panel > Programs > Programs and Features then select the Immunet and right click to uninstall.
Follow the instruction on the Wizard that will appear in your screen.
You can also use an application to make sure you have uninstalled it completely.
Use the Revo Uninstall Pro.
Hi Robert,
The Dut.DLL file is an executable file found under the windows library, this is normally found under C:Windows or C:Windowssystem32.
If the error says it can’t then you need to search the file under the root drive and then put it in the folder found above and also in the folder of the application under program files x86 and program file.
points
Hello brother,
This problem is happening because a system file named "Dut.dll" is missing. It is a common error when any DLL file is missing from the PC.
Here, in this techyv link, you will easily find out how to fix this issue.
Problems with .dll files missing
