TurboCASH Embedded VErsion : 4.2.0.3 Error
Hi there, I try to establish the connection between Activa and turboCash. However, the following error message appears and says that TurboCash has a dynamic SQL error. Please find the screenshot for your information.
Could anyone have any suggestion to fix this error? Thanks a lot. Have a good day.
SQL Error: Dynamic SQL Error SQL error code=@1 Table unknown @1 at line @1, column @2. Error Code: -204. Undefined name The SQL: SELECT * FROM BATOT28
