When I start to use TurboCASH, I realize immediately that some significant components are missing in the program. An error message appears indeed and please find below screenshot for your reference.
Could anyone explain the error and help me to find a solution to fix this? Thanks in advance. Have a nice day.
TurboCASH Version : 3.7.5.0 Error
Access violation at address 7C901010 in module ‘ntdll.dll’. Read of address 06CF2A1A
TurboCASH Version : 3.7.5.0 Error has occurred
Hi there Wesley J Douglas,
Unfortunately, this is a known bug and there is not much to do except using another version of the software or contacting the technical support.
However, there is a possible workaround to try – the problem is that the version you are trying to install is missing dbxdrivers.ini and dbxconnections.ini definition files for Report man. You should find those files in older or newer packages that you have available and manually copy them to the TurboCASH folder.
Best regards,
Drake Vivian
