Hi, I am using Nokia X6 mobile. It is Operating system is Symbian OS v9.4, Series 60 rel. 5. Recently I saw on my friend’s mobile, the software named joikuspot premium and he told it helps to turn our phone into a secured wi-fi hotspot. His mobile OS is android Jellybean. Is this software support to my Nokia X6? Please send the download link to download that software. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Turn our phone into a secured wi-fi hotspot
Hello Earl,
I found out part of your problem and that is the download link. I however did not find out instructions. Heres the download link for Joikuspot Premium for Nokia X6. I prefer that website because its free, but if it does not work try this website out but it does cost nearly $12.00. Sorry, this is all I could help you with.
-James C Montes.
Nokia X6 has a Symbian operating system.
The Android and Symbian have different software’s, so the Android Joikusport software is not supported on your Nokia X6.
You must download the Symbian version. You can download it here.
To get the premium version, you must pay for it. It costs $11.80. Buy it here.
It is very easy to use.
Just install the software and open it, then you will access all of their options.
