Turn Webcam in PC to Webcam House Security
Hi. I have a webcam here and I want to make use of it since I don't go cam to cam with my friends all the time. I want to have my own Webcam House Security but I don't know to make it like that. Help will really be appreciated, thanks!
Answered By 5 points N/A #165943
Hi Acilis,
You can surely and effectively use your webcam as your cheap home security system.
You just need to download and install a web cam monitoring software catering to your operating system running and there you are you will be able to control your in house movement with advance techniques such as motion detection and scheduler.
Following link would get you an appropriate software for the same purpose.
http://www.ugolog.com/pages/25-applications-to-turn-your-webcam-into-home-security-system
Hope this helps.
Thanks
Baker
