Darcie
220 points
Posted on - 05/24/2011
Hi
I have recently upgraded my Ubuntu desktop to unity. But the look and feel in not of my type, seriously. The desktop workspace switching is, good kids eye candy but not pleasing my old eyes. How do I remove this animation and just get a simple quick switch.
Turning off Ubuntu desktop cube rotation
Open a terminal window and type “ccsm”. The software should be able to guide you, out of the kindergarten !
Darcie
220 points
The program does not seem to be installed. Where do I get it?
You may need to type:
sudo apt-get install compizconfig-settings-manager
to install it.
Darcie
220 points
Thanks, that’s a good tool. I can use it to disable other head spinners too.
But there are a lot of options. Can you briefly tell me, which one shall turn off this cubic rotation?
May be you are looking for: Desktop>Desktop Wall>Viewport Switching set “Wall sliding duration” to 0. OR Desktop>Desktop Wall>Viewport Switch preview “Switch target preview visibility time” to 0.
Darcie
220 points
Thanks a lot. My head stopped spinning!
You can completely disable those features; uncheck, "Show Viewport Switcher Preview" and set, "Non Sliding Windows" to "any”.
Darcie
220 points
Thanks a lot that made it even faster!!
