TUSBAudio driver preinstallation failed to install
Hello Friends,
When I am trying to install XMOS/Thesycon, I ended with an error message. I have tried this installation Windows 7 and Windows XP, works well and good without any issues. But when I try in Windows 8 I am getting this error message. XMOS cannot in Windows 8? Please help me to get installed in windows 8 operating system. Thanks.
Error :
Setup
Preinstallation failed! Please run setup again. If you are asked to confirm installation of software, please confirm.
Answered By points N/A #188060
This error is occurring because of Windows’s driver signature checking. This setting is applied harder than x86 OS. So, what you’ve to do is to disable this option and then install the driver.
1. Press “Ctrl + X”.
2. From the pop-up menu, select “Command Prompt(admin)”.
3. When the console window comes, type and hit enter the following commands:
bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING ON
4. Now try to install your driver again.
If you have to re-enable this again, run the following commands;
bcdedit -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING OFF
