Tutorial on samsung star s 5233 setup
Hi there,
I have just received a Samsung android phone. This is my first android device and I am very impressed with the functionality offered by the device but seeing that I just came to an android phone from an old Nokia phone, this is all a very overwhelming experience.
Can anyone please guide for Samsung star s 5233 setup for receiving and sending email (pop3 and IMAP settings).
Thank you
Answered By 80 points N/A #168855
Greetings Anthony D Renda,
To set up POP3 and SMTP on your phone go to
  1. Menu > Messages > Email >  Press OK
  2. Give some name to your account.
  3. Now depending upon where you have your email the next data needs to be done correctly. I'm going to show example for Google mail (Gmail).
  4. Enter Email ID: yourid@gmail.com
  5. Enter your password.
  6. Incoming server type is POP3
  7. Incoming server is : pop3.gmail.com (This is for Gmail might be different for some other)
  8. Outgoing server SMTP is : smtp.gmail.com (This is for Gmail might be different for some other)
  9. Press ok and you should get a confirmation that The pop3 has been successfully completed.
  10. Then press back on your phone
  11. Select your email account you created
  12. You need to set this Values
  13. Secured connection: off
  14. POP3 port: 995
  15. SMTP Port : 587
  16. Check The option APOP Login.
  17. Download Limit: 500
  18. Secured connection: SSL (Choose SSL for second option not for the first)
  19. Retrieving Option: Select Subject only
  20. Keep On Server: Check it
  21. My Address: yourid@gmail.com
  22. Username /Password : same as you've set above
  23. POP before SMTP: Don't check
  24. SMTP Auth: Check
  25. Same as POP3/IMAP4 : Check
  26. Save All Settings on the end.
This should set up your phone email for Google mail.
Hope this helps you,
Regards.
