Kyle Berry
30 points
Posted on - 10/05/2012
Hello experts,
Tutorials about how to shred folder. Can you provide me a video tutorial or any website url link that will direct me to the webpage wherein it can show me the proper way of shredding folders without identifying any match. I hope you can give me the best solution to this.
Thank you.
Hello Kyle, For shredding of your files and folders, You need to download a file shredding software. I recommend File Shredder which would help you remove files from your hard drive without fear of being recovered.The download link for file shredder is mentioned below: http://www.fileshredder.org/
Hi Kyle,
For you to shred files, you need to download a software that can permanently delete everything you want to erase on your computer. I would suggest you to download and install the Evidence Nuker. It is a user-friendly software that allows you to permanently wipe out internet and system files. You can check it out and download it on this link : http://www.evidencenuker.com/.
Thanks
