Tutorials on importing table from MS Access through Command Line
How can I import table from ms access through command line? Are there any screen or video instructions that can guide me through this task?
Hi David Shawn,
You want import table from access that means you want to export access table to another program, right? Everything is simple. Just open your access file > choose table you want to export > go to menu File > Export… > in Save in, choose where to save your exported table > in Save as type, choose program you want to your table export to > in File name, set a name for your exported table > click on Export button.
If you want to export more tables, repeat these steps above.
Hope this helps
