Tutorials on Parsing and Storing XML Feeds
I need some feeds to parse and I am wondering where to store xml feed… Is there a guide or tutorial for this? I am just a beginner so it would be awesome if somebody could help me with this.
You can parse XML feeds using SimpleXML extension. It's easy, quick and more simple than using regular expressions to parse data from XML documents.
SimpleXML is a powerful tool and there are many tutorials for using this extension on the web.
For storing XML feed you should:Â
1) Â Open a connection.
2) Â Choose the database you want to store your data in.
3) Â Add records to the database using MySQL statements.
4) Â Close the connection.
