Is TV for PC available in the market
I've heard a TV for PC new gadget. I wonder if it is already or out in the market already? I want to have it first before my friends do!
You can watch tv on pc by using a tv tuner. A very easy method is to buy a usb tv tuner
     As of now there’s no web gadgets that allows anyone to watch tv online. The only way to watch direct to computer is by installing a tv tuner, you can choose internal or external tv tuner.  Â
thanks,
Yes, it is possible to watch and stream television on your desktop computer with a TV tuner either USB type or internal TV tuner card. Here are several you can check. The Hauppauge WinTV-HVR-2250. It is a dual TV tuner with infrared remote control. It features dual hybrid tuner with built-in TV splitter, dual built-in hardware MPEG-2 encoders, and MCE remote control with two infrared blasters.
It supports Windows XP, Windows Vista (Premium or Ultimate) with Media Center, Windows 7, and Windows 8. It requires Pentium 4 2.2 GHz processor or faster, graphics adapter with 64 MB video RAM or higher, sound card, and PCI Express card slot. Optical drive is required for installation only. It costs around $118.99. Another one is the KWorld UB445-U2 Hybrid TV Stick.
It supports Windows XP Service Pack 3 32-bit only, Windows Vista Service Pack 2, and Windows 7 both 32-bit and 64-bit. It requires Intel Core 2 Duo 2.4 GHz or faster processor, 512 MB RAM or higher, USB 2.0 port, and graphics adapter with 128 MB video RAM or higher that supports Microsoft DirectX 9.0c. It costs around $39.99.
