annie brown
20 points
Posted on - 08/02/2013
Hi Friends,
I am having a TV tuner card for PSP, I need to know is there any convertor that will save the TV visuals into avi or mp4 format. Please do the needful for mentioning the name of such converter that is available for free of cost from the internet.
Thanks, Annie Brown
There are a number of free options. Here is one that I found that allows you to convert videos to many different formats. My only caution is that many times free software tries to get you to install other programs which may slow down your computer so make sure you read everything carefully during the installation of any free software.
When you click on the link provided it will automatically start downloading the software for you. Once downloaded. Open file and follow steps for installation.Â
Here are some other options for free video converters.
