I have a TV tuner which was working properly recently however there has been a recent problem.
It is not responding anymore.
I have recycled al the reset process and still the outcome is same.
Under the circumstances I am in some major predicament.
So someone please instruct me about how to solve this problem.
Kenneth Feugo
Tv tuner not responding-what to do
Attach the CATV wire into the CATV (75 Ohm) elevate, don't go through your line box original; if you tally to, use a CATV manual worker to run a admirable fare to your device;
Lope the integrated say wire from the TV Tuner Card’s audio Frequency Out embrasure to your PC's aural in port on your sound roll.
Now get a ‘Fly2000 TV' software, might be chances are it was organized to react in better way. See if the endeavor writing allows you to difference channels and much. If so,
I suppose the problem may know been with WinDVR
