TV undetected in Windows XP with GeForce FX 5200
The cable of Windows XP computer with GeForce FX 5200 graphics card installed is not working. It is unable to detect the TV even though the UltraMon is installed. How can I resolve the issue? Do I have to change any hardware or install any software?
Answered By 5 points N/A #90396
There might some hardware and software that you might need to check if it has been installed. First, you will need to check and make sure the TV's antenna has been set properly and it has been connected to the computer. In case that place has some network problems, you will need to make sure that you have set the antenna high enough so that it can be able to pick the signals.
As for the software part, you will need to check and make sure that you have installed the TV card drivers. They are important and therefore you will need to get the installation CD and install them if you had not done that yet.
-Experttechyv
