TV VCR receiver Troubleshooting kindly reply
I want to set the input selection on my receiver and I want to make HDMI as the default one. When turning it off, and then turn it on again, it is set to the default connection.
However, when I turned the receiver off for more than 10 seconds, it will be set to TV/SAT.
How can I make it firm and set the receiver to HDMI automatically?
Please help.
Best Answer by Benson Sale
Answered By 5 points N/A #124310
Dear Friend!
If you see your owner’s manual chapter four, you can find the procedure to setup with detailed description. Default settings are written in the page number 41 in the above mentioned manual. This is my recommendations that you set the default settings in input selection at your initial stages.
Hope you can better start with the help of manual, manual can be download from it’s official website.
Thanks,
Answered By 0 points N/A #124311
Please download the manual and find there the complete procedure. You can find it on the Internet. For example, you can search on http://tv.manualsonline.com/manuals/device/tv_vcr_combo.html and select there the specific type of device you own.
