What is the use of tweaking tools on computers? Does it fine tune the software and hardware of the computer? Can tweak alter the underlying variable values? Does it make the program faster? Â Waiting for some answers.
Tweaking some tweaks on computers
Hey Kenny!
The meaning of Tweaking is to tune or adjust any electric device like computer. This term can also be used for small modifications for the purpose of system improvement.
This term can use for both, hardware and software, and the meaning of Tweak is different in both fields (Hardware and software).
If we talk about hardware, the process of modify the system, (like changing RAM, Voltage, clock rates etc) is called tweaking.
Now let us move towards the Software field. In softwares, Tweaking refers to tuning the system to improve its speed. Tweaking software reduces the burden of processes and maximizes the system speed. There are many software in the market that can be used for improving system speed and performance
Thanks
Dear Kenny
Small modifications to improve a system, is referred to as Tweaking. It can be defined as any tool or application that fine tunes a device or a system. Tweaking tools fine tune both the hardware and software depending on the type of application or tools used. Hardware tweaking is modification of clock rates, processing units, improving cooling systems, changing voltage, etc. Software tweaking aims at improving the performance of a particular application. It can be done either manually with the use of certain programmes or by using semi-automatic tweaking utilities used to increase the performance. It aims at increasing the usability and performance rather than the speed of the program.Â
Many thanks Tunacao_Caaron1 and Fabros Almonia! I really appreciate your help in informing me what tweaking is. Thank you very much. Thanks TechyV.
