The TweakUiPowertoySetup.exe installer is not working on my computer. Was this GetDirectoryDllW procedure added to kernel32.dll in the SP1? How can I fix it? Any idea would be greatly appreciated. Thanks in advance.
TweakUiPowertoySetup.exe – Entry Point Not Found
The procedure entry point GetDllDirectoryW could not be located in the dynamic link library KERNEL32.dll.
OK
Hi Michael,
I suggest to download the latest version of the TweakUiPowertoySetup.exe only the one that is compatible with your Operating System. Also check if you have updates for your Windows then if you have then its better to update it always do this to avoid the incompatibility issue. As the error says, I think the software are searching for KERNEL32.dll and did not find it to your computer so check it if you have that if you don't have it better to download and save it to your directory folder.
