I have this error on twitter on my iPad and I can’t connect. If I return to the previous website this error appears again and I can’t solve it. Is a solution for this error ? Is this an error ? Why I can’t access twitter when I am redirected ?
Thank you !
Woah there!
This page requires some information that was not provided. Please return to the site that sent you this page and try again… it was probably an honest mistake.
Twitter page requires some more information
The problem you are experiencing is the Twitter website rejecting your login credentials due to corrupted data being sent. The solution is:
1. Uninstall the Twitter app you're currently using by holding the icon until they all start to jiggle. An "X" in a circle will appear on the icons.
Tap the "X" on the icon of the app. Confirm deletion.
2. Download and install the latest version of the official Twitter app (Twitter for iOS 6.3) through the App Store
3. Re-enter your login credentials by going to Settings, tap Twitter, tap your username and type in your password again.
