Two printers prints the same document at the same time.
I am using two HP All-in-One Printers. Now what I want to do is to print same document on two printers at the same time. How can I command the printers to do that? Please help.
Hello Yuan.
If you are running Windows, you will need a third-party software to accomplish that.  AND Technologies has an application called MultiPrinter PortÂ
http://www.andtechnologies.com/index.php?q=free-software/multiprinter-port
It works on all Windows versions and is free to download and use. Â For it to work, you will be required to install a separate driver for every printer that you will be using even if the printers are of the same make and model. Â You can also set it up so that it prints out to a physical printer while it also prints out to a file.
I don't know of any such tool for Linux or Mac OS but I'll be sure to update you if I do find one.
Hope this helps!
