Type the copyright symbol, the registered symbol, and the trade mark
How can I type the copyright symbol, the registered symbol, and the trade mark symbol in Microsoft Office form my keyboard?
Hi Corey,
Using keyboard shortcuts for inserting special characters and symbols is much easier that the conventional way of using the Insert tap –> Symbol then having to search for your desired symbol in all the symbols available to insert it to your document. Below are some of the most useful shortcuts including the ones you asked for:
Copyright symbol —> ALT+CTRL+C
Registered symbol –> ALT+CTRL+R
Trademark symbol –> ALT+CTRL+T
Ellipsis –> ALT+CTRL+PERIOD
Optional hyphen –> CTRL+HYPHEN
Column break –>CTRL+SHFT+ENTER
Page break –> CTRL+ENTER
Line break –> SHFT+ENTER
Hope this is helpful.
Notifications
