Type Error on my Mozilla Firefox 3.6
I am browsing on my Mozilla Firefox when I got an error message that says,
“Type Error:    Components. Classes ['@mozilla.org/extensions/manager; 1’] is undefined.”
It appears on my screen simultaneously. What should I do? I was just doing my research and this error suddenly appears and never stops. Please help.
Answered By 0 points N/A #86189
Hello Albert,
You will keep its existing file or format. It lost the configuration of browse. The update soft would force to loss it. Don’t worry about it. You have to re install properly.
According to Antivirus attracted on online using it will trash the existing program. So make their two things sure which is actually had.
the bookmarking page and research page will very important to Mozilla. That mean it can provide your using. if you ask the online upgrade from related site. it can support you very much but already had the soft can serve you easy way to perform. Keep it up. Good time.
