What type of Virtual Private Network is good for my business? I have a small company from 5 employees, I need to create a VPN (Virtual Private Network). My team is from salespeople, who are not in fixed location. They are roaming users.
Type of Virtual Private Network
Hello Dillard Cristobal,
You will find that, Virtual Private Network is divided into two types. One is Internet Protocol Security and another one is Secure Sockets Layer.
You will be able to get access into the network by using both. The procedure is that, the private network will link you through the public network but in different ways.
Now the question is that, which one is better for a small business. Actually it is dependent on your existing hardware as well as it depends on the users that will get access from a remote distance.
Internet Protocol Security allows your users to get access into all application in your business network but only the existing users can get access here because this system doesn’t allow non-specified devices to access.
So in general Internet Protocol Security is more secured than Secure Sockets Layer. So if you need to permit your suppliers, customers and other clients to access in specific applications then choose Secure Sockets Layer and if you wish that only some specific employees will get access with specified devices then choose the Internet Protocol Security.
Have a profitable business with a secured network.
Thanks
