Hello Whiz,
The TZAC download and the installation went well and good without any problem. The problem is when I try to run or play the game, the error appears. I searched for some solution to fix the problem but not able to find one. I created the shortcut as it mentioned in the error message, but still the problem remains. Please help me to fix the error.
Couldn’t parse command line options. Please note that you have to set a game ID in a shortcut. Please either use predefined shortcuts or check the website for information on creating shortcuts to TZAC.exe
points
The TZAC is unable to play on Windows 7
It looks like there is some problem with the shortcut as it lacks of some command parameters. Installation of TZAC ANTICHEAT produces 4 shortcuts. So the choosing the right one is definitely hard enough.
From the Start menu search bar, type “tzac ET”. From the shortcut, run the game.
If this doesn’t fix, then download and install the latest one from here. Now it should work fine.
If that doesn’t work, then something is to do with Command Prompt.
1. Start Command Prompt with administration privilege. Right-click and select “Run as administrator”.
2. Run the following commands:
“cd d <path_to_ TZAC_Anticheat_TZAC.exe>
TZAC.exe <game_ID> <command_line_option>”
Game IDs are as following:
ET – 0
COD 4 – 3
COD 2 – 4
Now your game should run fine.
