Kaarenn
Posted on - 11/30/2011
Hi
In our company we are having Forefront Unified Access Gateway (UAG).
Recently we installed on our computers Windows 7 and we have installed new version of UAG, but we got error message.
Can someone please help me with this problem?
Tnx,
Karen
Configuration
The configuration cannot be located from Forcefront TMG storage.
An unrecoverable error has occurred. The application will close.
lee hung
75 points
UAG configuration error message from TMG storage
Hello Kaarenn,
Where is the Forefront Unified Access stored? In case you have stored it on the network and you are trying to install it by accessing it remotely, then there could be a problem with the network connection on the PC that you are on or there some credentials that are required for you to do the installation.
I will suggest that you try installing the application from a stand alone environment and then share it on the network when the installation finishes successfully.
You should also check to ensure that you are running it using administrative credentials.
Hope this helps.
__
Regards
Lee Hung
Try this one make sure the UAG server should excepted from the such as group policies or maybe any policies should excepted and then simply the computer from the group policy make sure ensures not automatically be clean it up and then the setting should be applied from the polices and then make sure to disabling them after they applied from the computer and should not back in the setting.
Make sure the machine can compatible from the Vm software before you install the software from your computer and then after you install the TMG services make sure have happening effectively and then if its finish using the Event Viewer from there stare the set to automatic stopped just simply try that one if working at all.
Ben
