Hello experts,
How to stop ubisoft auto update? There are some instances that I don’t understand for I didn’t get any move to get an auto update for any kind of software in ubisoft but now it keeps on popping up on my screen and it annoys me too much. Is there a way that I can block this update for it will not disturb me anymore?
Thank you.
Ubisoft Auto Update Keeps Showing Automatically
Hello Stephen,
You are getting a desktop notification because you might be using a Ubisoft product.
You need to find out which of the product of ubisoft you are using currently.
Simply Goto > Control Panel > Program And Settings > Uninstall or Change a Program > Dounle click the Ubisoft Product and follow up the screen Instructions.After a successful uninstallation Restart your computer.
Hopefully this would work.
If you want to update your software then you need to press the update button form the message that pops up on your screen by connecting over the network. If you want to disable the popup message then it is possible form the program control panel search for update panel and set it as manual update. Now you will be able to update the program manually when ever you require updating your program.
Smith Thompson
