Ubuntu error- try hd(0,0) not set
Hi, When I install the Ubuntu on my machine it says, "try hd (0,0) error "prefix" is not set." What does this mean?
This is a common problem in ubuntu which is installed inside windows because of the swap file corruption because of a bug in some ubuntu versions and that file is used to migrate and store ubuntu system and your personal files inside , fortunately you can enjoy ubuntu using full install (you can even do that without uninstalling windows and I will show how) please follow those steps :
1 – Install Virtualbox https://www.virtualbox.org/wiki/Downloads (windows version)
2 – Download latest version of ubuntu https://www.ubuntu.com/download/desktop
3 – Run the program
4 – Select New to create a new virtual machine. Then click Next.
5 – Select a Name for it and then select the Linux system from the drop down list
6 – Select the Ram allocation its better to leave it by default it will recommend the Ram according your PC performance.
7 – Select Next, Then select Next , Then Next again
8 – Select storage space
9 – Then Next and Finally finish
10 – Select the Ubuntu ISO file
11 – Double click on your Virtual machine name to start it up
Finally follow the installation procedures of Ubuntu
Notifications
