I recently bought a RealTL8188CU wireless LAN adapter.
It works perfectly in Windows but in Ubuntu Linux it detects the network but does not connect.
What could be the problem?
Anyone could help me?
Ubuntu Linux Network not connected
You may need to check your operating system’s compatibility with this hardware. Realtek RTL8188CU is a USB 2.0 150 Mbps mini-wireless N network adapter. This device can be installed on a computer that is running on Windows 2000, Windows XP 32-bit and 64-bit, Windows Server 2003 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, Windows 7 32-bit and 64-bit, Windows Server 2008 R2, Mac OS X 10.4/10.5/10.6, or Linux kernel 2.6 platform. Check if you are using the version of Linux that is compatible with this device.
You may also try downloading Realtek RTL8188CU’s driver.
You can also download its PDF manual.
Of course, you must have Adobe Reader installed on your computer to be able to open the manual.
You can also download its Data Sheet.
