Ubuntu not detecting my web camera??????
Why is ubuntu not detecting my in build camera in my laptop. I have tried everything possible but it is not still working.
Please assist with a solution
As always, before you can use the built-in camera on your laptop, the software for the camera should first be installed. When you install Linux on your laptop or any operating system, the driver for the built-in camera is not included in the installation. Installing it is a separate task. To make the camera work, you need the camera software that will work or that supports Linux.
Here are several webcam software for Linux and check which one will work for you. Try downloading Cheese 3.14.2 Webcam software. To install, run the following commands:
The last command “make install” should be executed as root. The next software you can try is Motion and installing it is easy because it is available via the Ubuntu Software Center. If you want to install it manually, run the following command in a terminal:
To edit the configuration file, run the following command:
When you are done configuring Motion, you can start the application by running the following command:
To know more about Motion, visit Motion Installation Guide.
