Ubuntu Rackspace Cloud Server Error
I cannot apply the rules of iptable with Ubuntu Rackspace cloud server.  I am getting an error message which says that ‘it cannot able to start the table filter.’ Please help anybody to solve the problem. I will be thankful for all types of help and support.
Answered By 20 points N/A #91962
Hello Mildred,
Can you please write the error as it appears on your terminal or error window? I have searched that on Ubuntu forums but without the exact error message i am not able to fix it. At the moment i can only assume that your iptables.rules file is incongruent with the kernel module you are using. You can also use a little more detail of the problem. What is that exactly what you are trying to do with iptables and what step was problematic for you?. I have found more on this forum. Also, providing a screenshot in problem reporting helps a lot. It makes problem identification lot more easier and accurate.
Have a nice day!
Abe.
