Ulead gif animator nav bar for win 7
I am using win 7 64-bit i want to create a gif animator nav bar for win 7 if someone knows about how to create Lead gif animator nav bar for win 7 then please tell me.
Hello Jeffrey,
You will need a third party application such as Gifture, for that purpose.
You might want to consider other applications just to be sure that the application you are using is compatible with your windows 7 operating system.
A tutorial on how to use the app may also be handy.
Nicke
Dear Jefrey Downer,
The solution in such a case can be done by doing the
Following steps:
Hope that was helpful for you.
With my best regards,
Don Muench
