Please solve my problem. Today Ulead GIF Animator software doesn’t allow me to edit a .avi file in it. I never faced this problem before. what should I do to edit that avi file in ulead Gif animator?
unable to read the video file. 'C:Documents and settingsusermy documents Any video converterAVI You know what OI' Jack Burton always Says.. _xvid.avi'
Ulead GIF animator software error message
Hello Susan,
Have you installed any new software on your computer recently, for they may be the ones causing the issue you are having right now when using your ULead GIF Animator.
You will also need to check the hardware devices on your computer, for instance the RAM modules, the hard disk and so forth. You can opt to download some memory diagnose program to test memory issues on your computer. In case there is something wrong with the hardware devices, you may use the system but some files may end up being corrupt.
Hope this will help you workaround the issue.
Carl
