Ulead VideoStudio Movie Wizard Error
Hi dear,
I install driver for Ulead Video Studio but why this error appear again and again In Adobe Illustrator.
Either no video capture driver is installed in this system or no device is connected
Either no video capture driver is installed in this system, or no device is connected.
OK
Thanks in advance for providing help.
Answered By 5 points N/A #116981
If your are encountering this kind of problem then you must perform the following solutions. If you are using Ulead Video Studio 7, go to “Menu” select “File” click “Capture Plug-in” locate and select from the drop down menu the “ADS Instant DVD USB2 Caputre Plug-in.
Click OK. On Ulead Video Studio 8 users and later, select “Change Capture Plug-in” from “Tools” and click on “ADS Instant DVD USB2 Capture Plug-in under the drop down menu and click OK.
If the problem still get in your way, try uninstalling Adobe Illustrator and Ulead Video Studio Maker, and installing first the Ulead software before AI.
