Ultimate Solution: My iPhone Won’t Restore After The Update.
I updated my iPhone and after that when I connect iPhone and launch iTunes nothing worked. Please tell me a solution my iPhone won't restore after the update.
The reason behind this issue is iTunes is unable to recognize your iPhone.
Make sure that iTunes is of the latest version and security software exists.
If still the problem persists then try the following:
(i) Switch off your iPhone.
(ii) Plug in USB to the system.
(iii) Launch iTunes.
(iv) Hold down the Home button for a few seconds.
(v) When you see connect to iTunes, release the button.
(vi) Connect iPhone to USB
(vii) A message will be displayed "iTunes has detected an iPhone in Recover".
