Ultra Recall Professional has an error
I just tried using Launchy to Copy with the latest V2 of UR, importing a web page from Firefox via Launchy (I used the copy command provided in the XML script, at: https://www.kinook.com/Forum/showthre…?threadid=1336-(Samplesite) doesn't work, and causes an access violation too…
Is this because the Launchy XML is wrong for V2 – or is it because there are some general errors by importing in V2, as I and others have experienced repeated access violations using V2? Help me to fix it. Thanks.
Access violation
Exception 0×C0000005 occurred in module C:Program FilesUltraRecall.exe at address 0×2DEEC559, offset 0×0004C559.
OK
