Ultra VNC Wrong Machine Connection
Hello people. I had a great experience after deploying UltraVNC. It was working great, and I had done the deployment through Group Policy. Everything is fine except for a tiny glitch. When connecting to a host it connects me to the wrong machine. I enter the name of one host, and I end up being connected to another. However I must add that for some machines it has been working perfectly well. The only category of machines that it is not connected accurately is the CAD lab. Thanks much. Jane.
Answered By 0 points N/A #155342
Hi Jane,
Ultra VNC are very easy to use. This wrong machine connection problems are seldom happens, sometimes it failed to connect or it was connected to wrong computer. I have some solutions that you may try:
1. To connect to the remote services, you must have the address
on the local area network and not on the private bridged interface for the virtual machine. Right click on the your virtual machine and choose settings, then go to network tab and change the Attached to default setting for Bridged Adapter which is NAT.
2. On the computer that running VNC server, you can try to do this: On the windows start menu, click run and open cmd.exe
And then write cmd:> nbtstat -RR -r
