Un-installation error of Code composer Studio
I am getting an error message pop up when I try to uninstall Code composer Studio V5. So I can't uninstall CCS from my PC. This is really annoying. How can I  uninstall Code composer Studio from my PC now? Thanks in advance.
Details and screenshot of error :
Uninstalling Code composer Studio V5
Application Error
Error : Error in action ExecuteAction
Error in action RenameFile
error renaming "C:/ti/ccsv5/un…
Best Answer by Kumay Edwards
Answered By 0 points N/A #132168
This is a regular Problem. You can use Different Software's to remove programs from your computer which is very easy process. One of the program is TuneUp Utilities you can download trial version from here;
https://www.avg.com/en-us/tuneup-utilities
and remove your program. This process is very efficient. Install TuneUp Utilities and use Uninstall Manager to remove your program.
Thanks
Answered By 5 points N/A #132169
Dear Vicky,
By the looks of the crudeness of this software's installer I would not be surprised if it had a bug that prevented it from uninstalling off your system smoothly. It is always recommended to uninstall all programs via the Add or Remove Programs in Control Panel. However, for this software I think you should look for an Uninstall executable within its own Program Files. (Find the location where it is installed and look around the folders there)
Even then if you don't find one then you can go ahead and simply "Delete" CCS from your system and it will not affect your PC in any negative way, I guarantee.
To do that click on the Folder where CCS is installed and press Shift+Del on your keyboard. This will permanently Delete it from your system.
After that you can restart your computer once just to be sure. You'll see that there will be no problems.
Note that if you still see CCS in the Add or Remove programs list after you have deleted it, you can simply remove its name from the list.
Regards
Kumay Edwards
Answered By 0 points N/A #132170
Hello Vicky,
Performing these techniques you can also see another Techyv post's solutions which will be helpful for you too to fix this issue.
Code composer studio v5 setu
Answered By 590495 points N/A #307022
One possible reason for this error is file corruption. Try installing the program again to overwrite the existing installation. This will fix any corrupt file since it will be overwritten by a working file. Once the installation is complete, try uninstalling it again from the Control Panel. Click “Start,” “Control Panel,” and then “Add or Remove Programs.”
Select “Code Composer Studio” and click “Uninstall” or “Remove” then follow the instructions. If you can’t uninstall it from the Control Panel or it doesn’t appear in the Control Panel, run the program’s built-in uninstaller. Click “Start,” “All Programs,” “Code Composer Studio,” and then click “Uninstall.” If you still can’t uninstall the program, download the free trial of Revo Uninstaller Pro and install it.
Once installed, start Revo Uninstaller then select your Code Composer Studio from the list and click “Forced Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftovers and then delete everything it finds. This will remove everything the program created on your computer.
